T56 Problems
Old Dec 24, 2007 | 05:51 PM
Scott02WS6's Avatar
Default T56 Problems
Ok I Have A 02 Ws6, The Problem Is That The Shifter Is Very Very Stiff. I Have Never Had This Problem Before, Even In Neutral Position I Can Barely Move It, Is My Shift Linkage The Problem?? Going Into Any Gear Is A Workout Entirely, the clutch seems to be working fine, it has normal pressure and is grabbing. The Car Is Just Sittin Right Now But Im Military And Need It To Drive Back Once My Leave Is Up. Want To Fix The Problem Myself But I Dont Want To Spend My Entire Vaction Working On My Trans. Any Input Is Helpful, Thanks Alot Guys
Scott
Old Dec 24, 2007 | 06:00 PM
yellowbird1232's Avatar
Tech Fanatic
Does it make a difference if the engine is running or not?
Old Dec 24, 2007 | 06:05 PM
Scott02WS6's Avatar
no it is all the same when the car is off and running, i can bearly move it
Old Dec 24, 2007 | 06:51 PM
Tech Fanatic
What were you doing when it started? Going thru the gears hard etc? It sounds like a possible bent fork or shift rail.
Old Dec 24, 2007 | 06:52 PM
Tech Fanatic
You could take the shifter off and see if it is the problem.
Old Dec 24, 2007 | 07:01 PM
Scott02WS6's Avatar
I went a few passes on it, It stuck it in forth gear I had to jam on it to get it out of gear. I drove it home with few problems but then it just completely tightened up.
Old Dec 25, 2007 | 11:30 AM
94lt105's Avatar
Like Yellowbird said.. remove the shifter and see if that is the problem. If u can get a new/aftermarket one.. That would be good also. Let us know what happens.
Vince
Old Dec 25, 2007 | 11:04 PM
1BADAIR's Avatar
if it got stuck in forth you probably broke the keys
