Trouble hitting gears under hard acceleration
Old 01-05-2008 | 11:38 PM
linegtdt52's Avatar
Default part
hey dude you might wanna check that part and see if that part number is the same slave for 98 all the way to 02 cars for Oreily's because if it is it could be that damn slave they sold you.
Old 06-01-2008 | 06:10 AM
jugz ss's Avatar
wat up...im new to these forums.....but i was lookin at this thread
i have the same problem....the trany bloks me outa 3rd evry time im at high rpm.........i was reading wat yal posted but im not quite understanding wat the problem could b..........would u mind explaining???
and wats this drill mod???
Old 06-01-2008 | 08:42 AM
linegtdt52's Avatar
look under search and type in drill mod
Old 06-01-2008 | 01:33 PM
kkslds's Avatar
I rebuilt my tranny with lv. 1 sixspeedsinc. package and I bought a used mcleoud master and rebuilt it with the willwood kit and all seems better now. I havent raced it much yet so I'll have to keep you posted when I do.
Old 06-01-2008 | 04:42 PM
99z28monster's Avatar
had my tranny rebuilt and works perfectly now.
Old 06-01-2008 | 05:32 PM
vetteboyc5's Avatar
On my 99 c5 Im having issues similar..
When I get up to about 6500 RPM. and shift, The clutch pedal gets as hard as a rock, and its almost impossible to shift it into gear.
What causes the pedal to get hard as a rock at High rpm like that? Then after that youll be pulling away from a stop, when u barely let off the pedal, the clutch harshly engages, I mean as soon as your foot moves back its engaged literally jumping forward like you popped the clutch, no gradual engagement/normal slipppage to pull off smoothly.
The master is stock, and new, slave is stock and new. Drill mod performed, Stock Ls6 clutch?(Car has 415WHP)
Is it the clutch or are my hydraulics no good even though they are new?
