clutch master resevoir
Old 01-06-2008, 12:50 AM
zrocket_99's Avatar
Default clutch master resevoir
i should know this, but i new to the hydrolic clutch sysem. i was wanting to know about the rubber bladder in the resevoir. when i am putting more fluid in the resevoir do i take the rubber peice out and fill the resevoir then put the rubber thing back in then the cap or do i pour the fluid in the rubber bladder thing. thanks in advance
Old 01-06-2008, 01:42 AM
ae13291's Avatar
tske the rubber out, then put in the fluid
Old 01-06-2008, 09:16 AM
zrocket_99's Avatar
alrighty i appreciate it. i was just wondering cause, when i went to check it there was nothing inside the rubber bladder thing, so i took it out and there was fluid under it, and when i check the rubber bladder i seen there were no holes in it, so i got really confused, if you dont put the fluid in rubber bladder, whats the point of having in there?
