Need Tranny advice!
The f-body t56 will definately be cheaper to build, but the mn12 t56's are know to shift better due to the improved syncos. We can build an mn12 utilizing a custom mainshaft in order to make it "viperized" even though the viper shaft itself will not work due to the syncro design.
With either transmission, I would go with the larger output shaft at that torque level.
I also advise the Viper conversion way and everyone is different. We have seen great things from them and will continue seeing great things.
The M12 will always shift better due to the triple cone blocker rings but I don't notice much difference from my 02 Camaro to my 02 Z06. For the cost the viper is the better way with that power level.
Call me if you need pricing or check out the website.
Amber
Make sure your clutch adjustment is on the money and you don't miss any gears and it should last for a long time .
To upgrade the mn12 the cost for the mainshaft alone (same that is used in Rocklands Tranzilla) would add $400 and the triple cone syncros would also add $300 to the cost of our $1400 viper shaft trans:
https://ls1tech.com/forums/sponsor-sales-specials/839513-crazy-sale-tick-performance-extreme-viper-t56-1400-a.html
Both will handle the expected hp/tq
Thanks,
Jonathan
thesource, if you need that part number call me or pm me. That is the only we have used here are the shop.
Amber
