shifting problems at WOT!
Old Apr 5, 2008 | 06:38 PM
corvet786c's Avatar
Originally Posted by zrocket_99
i've got a 00'trans am. upgraded hydrolics, centerforce dual friction clutch. when i am driving normal, or at half throttle, i can shift fine and fast and everything seems to work fine, but when i get to WOT and rpm's get high, when i try to shift, it wont let me go into gear, i have to hold it there for a second or two, and when the rpm's get back down it slides right in, i dont understand it, it dont grind or anything, it just dont let me into gear. say for example, driving normal from 2nd to 3rd it goes it quick and easy, but WOT from 2nd to 3rd i have to keep the clutch in and hold it up there till the rpm's get down and then slides right in, wont let me get into gear at high rpm's. Any one got any suggestions.
I have the same problem, and you need to get your flywheel balanced. I just bought a cf fw steel and I hope this works. CF says that in the upper rpms if the flywheel is not 0 balanced then the weights in the pressure plate get throun to one side and makes it hard to shift.
Old Apr 6, 2008 | 02:45 AM
Mecinoid's Avatar
Originally Posted by wrencher
These problems areusually always hydraulics.
Do you have an adjustable master?
Seen a properly adjusted master & the drill mod do wonders.
+1 - Let me add make sure your fluid is really clean and I'd suggest upgrading to Motul or some other Hi-Temp fluid for the win.
'98 Formula 6spd(Redline fluid) - B & M Ripper Shifter, Centerforce DF, McLeod Adj Master(Motul Hi temp), drill mod, Redline diff fluid, 3.5 LPE driveshaft, 3.73 Auburn, Air bag right rear, Global West Traclink. (These are the main things that involve this post)
Plain Jane huh?
