Problem Installing Tranny
I have been having a lot of problems with my tranny. I broke a bell housing and stripped out a bolt on the new one and taken the transmision in and out at least 4 to 5 time.
So here is my problem, I installed the clutch using a clutch alignment tool doing my best to align everything with the pilot bushing and then I torqued the pressure plate progressivly in a criss cross manner. I put the bell housing on the motor and torque the bell housing bolts. Then I jack the transmission and slide it into place but I have 1/4 to 1/8 inch gap. I crank down on the tranny to bell housing bolts but I get to the point where I am afraid of breaking the bell housing again or stripping out a hole. I am cranking down on these bolt as evenly as I possibly can and I am doing this on my back with a few friends.
I have checked the alignment pins on the transmission and everything is lined up. I have tried my best to align the clutch. I have "tapped" on the back of the transmission. I wiggled around a redid the steps I told you above. I have talked to it, screamed at it, sweared at it and it just wont go in.
So has anyone else had this problem.
Tilly
good luck
I got snagged up this weekend with it and thats how we did it.
Every car is different.
Thanks for the help. I think what the problem is that I am having an issue getting the tranny lined up with the pilot bearing. I have the clutch disk engage with the transmission but its that last 1/4 to 1/8in which is killing me.
I have tried banging on it, and wiggling it. I also check the compression with the slave cylinder. I tried brining it in with tightening the bolts down (broke my first bell housing that way and stripped out another hole on the new bell housing). SO I figured that I would pay some one a little bit who knows what there doing because first, I am tired of working on my car (started this project in AUG'06 and I haven't driven the car since FEB'06) and I have lost my patience with it, and secondly I start school on Wednesday.
Thanks for the help, and now I know what to look for on my next attempt for tranny installation
Tilly
So i was doing everything right and should have checked to see if I could have slide the pilot bearing on the input shaft, before I installed the tranny. (Whoops)
