Clutch Experts Help!!!!!
Old Feb 8, 2008 | 12:12 AM
Arc00TA's Avatar
So heres what you do, be smarter than the pedal, get out of the car and pump it with your hand. If theres a lot of air it will have to be pulled back manually because the spring on the pedal is pretty stiff. I had to do this for 15 minutes when I put my new master in with a used tranny for my swap. But like they said you MUST leave the pedal to the floor when your buddy closes the valve or it will just suck air right back in. Also, make sure you check your reservoir level now and again.
Old Feb 8, 2008 | 01:07 AM
SladeX's Avatar
you push in the clutch, you hold it in, you crack the bleeder for a few seconds at most, close bleeder and release the clutch. More than likely you NEED to pull back the pedal to replace the lost fluid with fluid from the reservoir. After a few pumps it should come back, if not, pump the pedal than repeat the above.
It just takes time to do it, you can't expect a clutch to bleed in a few mins, for me it takes a good 7-8 tried before I get it back to the feel I like.
Old Feb 8, 2008 | 06:34 AM
99corvette's Avatar
yeah thats how we were doing it, but could never get it to stay stiff
Old Feb 8, 2008 | 12:16 PM
Arc00TA's Avatar
Disconnect the QD and push it in with a screwdriver to bleed that first, then hook it up and bleed the slave.
Old Feb 8, 2008 | 01:04 PM
99z28monster's Avatar
I had the same issues as the op, what was wrong was I had messed up the slave bleeder valve by tightening it down to tight thus smashing the tip of it. Which allowed air to get into the system because it would not seal.
Old Feb 8, 2008 | 02:36 PM
stevied916's Avatar
your master is bad or there is air in the system. You can try a mityvac. I think harbor freight has them for $40
Old Feb 8, 2008 | 02:56 PM
99corvette's Avatar
ok i might have to check that out, yeah i was thinking about just replacing the master and slave and being done with it. my clutch pedal would accasional stick to the floor so i was kinda thinking it was the master
Old Feb 23, 2008 | 09:07 PM
2KnbmTA's Avatar
how many miles and are they stock hydraulics? MAKE SURE YOU DO THE DRILL MOD!!!
if they are stock with some miles on them i would def replace them
Old Feb 23, 2008 | 09:20 PM
LS1Silverado05's Avatar
I have new master (made adjustable), new slave,fresh clutch, fresh flywheel, mity-vac bled, and I still gets ome trouble out of mine! Dont assume new parts are the answer. Try bleeding the living **** out of it, before anything else!
Old Feb 24, 2008 | 03:10 AM
99corvette's Avatar
Im putting a new slave in the next few days, ill post up if that fixed it.
Old Mar 7, 2008 | 01:52 AM
99corvette's Avatar
Ok guys, i put a brand new slave in, and that didnt fix it, so then i put a new master in, and it works now! It was a bad naster this whole time!!
Old Mar 7, 2008 | 01:31 PM
  #32
speed_demon24's Avatar
Just to let you know RAM doesn't reccomend using a stock flywheel with the HD, and if you do it will wear out alot faster than it should.
Old Mar 8, 2008 | 12:56 AM
  #33
99corvette's Avatar
Yeah i know, but they say that because they want you to buy thier flyhwheel. The shop that put mine in said they have put in about 40 of them last year and they all had stock flywheels except one. I dont drive the car daily so im not to worried about it.
Old Mar 8, 2008 | 12:25 PM
  #34
I talked to a guy who pulled an HD out of his car with 30k on it and he said his stock flywheel was pretty much shot. Let me know how it holds up since this is the clutch I want to put in my car next and if I can save $400 that would be a huge + for me.
Old Mar 8, 2008 | 06:28 PM
  #35
Viper's Avatar
I had a RAM980 with a stock flywheel, only lasted 10K. Flywheel was absolutely shot. This time around I did a Clutchmasters with a new billet steel flywheel and it's lasted 30K so far. FWIW.
Old Mar 9, 2008 | 11:05 AM
  #36
99corvette's Avatar
Well i might consider it soon then. I also thought yall should know that the master i had put in it lasted about 2 miles down the road and then took a dump on me. So DONT GET A MASTER from a auto parts store. I had to put a RAM Adjustable in it.
