Who Has A Centerforce Dual Friction Clutch?? (12")
Did you change out your pilot bearing? Stock flywheel? If it is was it resurfaced AND balanced? The first centerforce i put in had the same problem but it was due to me not replacing the pilot bearing and not getting the clutch/flywheel balanced.
Centerforce DF are good clutches, I've installed a couple of them with no complaints. As far as high rpm shifting, thats a known problem to all six speeds. Try an adjustable master cylinder, shim the clutch, and check to make sure when you did the drill mod the the hole was opened up completely. Sometimes the drill bit isn't long enough to clean it out good. If you do all of that and still have problems, you may have some issues with the tranny. I ended having mine rebuilt for high speed shifting.
I did like my centerforce...It chattered a bit but it was ok. Now its at 12k miles and slps in 6th gear. And now I have found that centerforce will not sell just the disc and I will have to buy a whole new setup. No way my car is making more than 320rwhp and that clutch is said to handle 500rwhp with SC/Turbo/NO2.
I know its a old post but I thought I would update everyone, 11.5k miles and my weight system took a crap, see my eariler posts from jan 09 about me worrying about it and now it happened, I am calling centerforce to see if there is anything they can do for me, the clutch still has plenty off beef on it.
