TSB number for T-56 woes?????
Re: TSB number for T-56 woes?????
Nevermind....
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
02-07-30-028 JUN 02 A/T - Serial Number/Site Code Locations/Identification
02-09-41-001 JUN 02 Computers & Controls - DTC's Set When Replacing Modules
01-06-01-023A JUN 02 Engine - Higher Than Normal Oil Consumption
02-06-01-026 JUN 02 Engine - Identification Information
02-06-04-023A JUN 02 Engine Controls - Spark Knock/MIL ON/ DTC P0332 Set
02-07-30-024 MAY 02 A/T - Cracked/Broken Case Diagnosis
02-08-66-006 MAY 02 Gas Cap Tether - Rivet Breakage
02-08-46-006 MAY 02 OnStar (R) - Incorrect GPS Location During OnStar Call
02-08-42-004 APR 02 A/T - PRNDL Display Dim for One Minute
02-08-46-004 APR 02 OnStar System (R) - Cellular Error Messages
01-07-30-023B MAR 02 A/T - 4L60-E Harsh 1-2 Gear Upshift/MIL/SES/CEL ON
99-08-51-007A MAR 02 Aluminum Wheels - Refinishing
02-08-64-005 MAR 02 Door Handle (Inside) - Rattles
02-06-01-008 MAR 02 Engine - New Prelube Tool
02-08-42-001 MAR 02 Polycarbonate Headlamp - Chemical Damage
02-08-44-003 MAR 02 Speakers - Buzz/Rattle Sound
02-07-31-001 FEB 02 Clutch Pedal - Scraping Noise/Return Spring Breaks
99-00-89-019B FEB 02 Warranty - Parts Return Program Explained
02-07-30-001 JAN 02 A/T - 4L60E/4L65E DTC P1870 Diagnostics
02-07-30-003 JAN 02 A/T - New Design Reaction Shell Thrust Washer
00-00-89-027A JAN 02 Interior - New Odor Elimination Product
01-03-10-012 JAN 02 Wheel Balance/Alignment - Labor Operation Guidelines
01-01-38-013 DEC 01 A/C Compressor - Diagnostic Considerations
01-07-30-041 DEC 01 A/T - Fluid Leak Diagnosis
01-07-30-038 DEC 01 A/T - Poor Performance/SES Lamp ON/DTC P0757 Set
00-05-22-002A DEC 01 Brake Rotor - Warranty Service Procedure
01-08-46-006A DEC 01 Onstar(R) - Antenna Coupling Revised Procedures
01-08-57-009 DEC 01 Rear Floor/Trunk - Wet On Top Of Axle
01-03-10-011 DEC 01 Tires - Sidewall Damage
01-06-04-044 NOV 01 EVAP System - Special Tool Usage
01-06-01-027 NOV 01 Engine - Cylinder Head Replacement Revision
01-08-97-002 NOV 01 HomeLink(R) Transmitter - Programming Difficulties
01-07-31-002 NOV 01 M/T - Improved Clutch Bleeding Procedure
01-03-10-009 NOV 01 Wheel Nut Covers - Loose/Missing
01-07-30-029 OCT 01 A/T - Core Return Product Feedback Form
00-06-04-011A OCT 01 EVAP System - Monitor Strategy
01-08-51-003 OCT 01 Vehicle - Interior/Exterior Anti-Corrosion Materials
01-00-89-014 OCT 01 Warranty - Standard and Optional Administration Process
01-00-89-013 SEP 01 RKE Transmitter - Correct Use of Labor Operation R4490
01-01-39-003 AUG 01 A/C - Screen Filter Kit
01-08-46-004 AUG 01 Cellular Phones - Operating Characteristics
01-00-89-011A AUG 01 Technical Assistance Form - New
01-01-38-006A JUL 01 A/C - Proper Flushing Procedures
01-08-64-003A JUL 01 Power Window - Motor Noisy
01-00-89-010 JUN 01 Diagnostic Worksheet - Usage
01-09-40-002 JUN 01 Seat Belt System - Collision Replacement Guidelines
99-01-39-004A MAY 01 A/C - Odor Emission in Hot Weather
01-00-89-009 MAY 01 Key/Key Number/Security Chip - Replacement
01-07-29-003A MAY 01 M/T - Jumps Out Of Third Gear
01-08-46-001 MAY 01 On Star Module - Required Reconfiguration
01-07-30-021 MAY 01 Park/Neutral Switch - Connector Hard to Remove
00-03-10-003B MAY 01 Tires - Bumper To Bumper Warranty Coverage
01-07-30-012 APR 01 A/T - 4L60 E Revised Valve Body/Spacer/Gaskets
01-07-30-020 APR 01 A/T - 4L60E Valve Body/Spacer/Gasket Kit Reference
99-07-30-020A APR 01 A/T - Service Procedure Changes
01-08-97-001 APR 01 Homelink - Transmitter Test Kit
01-08-44-005 APR 01 Radio Display - Error Code Diagnosis/Repair
01-00-89-08 APR 01 Service Information 2000 - Campaign Access
01-02-32-004 APR 01 Special Tools - Power Steering System Analyzer
01-08-58-002 APR 01 Windnoise/Water Leak - Diagnostic Guide
01-07-30-010 MAR 01 A/T - Torque Converter Replacement Guidelines
01-02-35-001 MAR 01 Air Bag - Squeaks When Turning Steering Wheel
01-06-01-011 MAR 01 Engine - Oil Consumption Guidelines
01-00-89-006 MAR 01 Technical Service Bulletins - Summary
01-05-23-001 FEB 01 Brake Rotor - Lateral Runout Correction System
01-08-42-001 FEB 01 Exterior Lamps - Condensation & Replacement Guidelines
01-00-90-001A FEB 01 Rear Axle Lubricant - Recommendations
01-07-30-007 FEB 01 Torque Converter - Bolt Design Update
00-00-89-15A FEB 01 Warranty Administration - Repair Order Documentation
01-08-48-001 FEB 01 Windshield Reveal Molding - Squeak Noise
01-00-90-001 JAN 01 Rear Axle - Lubricant Recommendations
00-08-48-005 DEC 00 Glass - Distortion Explanation
00-08-57-004 DEC 00 Rear Hatch - Water Runs Out of Corners
00-00-89-029 DEC 00 Vehicle - Warranty Labor Time Guides Update
00-03-10-006 NOV 00 Tires - Radial Force Variation
00-00-89-025 NOV 00 Vehicle - Labor Time Updates
00-00-89-023 OCT 00 Labor Time Guide - 10/2000 Update
00-08-110-004 OCT 00 Rear Quarter Trim - Visible Gaps
00-01-38-007 SEP 00 A/C Performance/Leaks - Diagnostic Procedure
00-00-89-020 SEP 00 Labor Time Guide - 09/2000 Update
00-08-46-002 SEP 00 OnStar(R) - Cellular Antenna Replacement Parts Available
00-00-89-021 AUG 00 Cross Line - Warranty Information
00-00-89-019 AUG 00 Electrical Relay - Labor Operation Numbers Update
00-06-04-033 AUG 00 Emissions - Enhanced Inspection Program Manual
00-06-01-016 AUG 00 Engine - Aluminum Thread Repair Kits
00-06-02-006 AUG 00 Engine Coolant - Information
00-06-04-036 AUG 00 Fuel Filler Cap - Contacts Quarter Panel
00-00-89-017 AUG 00 Labor Time - 08/2000 Updates
00-00-89-014 JUL 00 Labor Time - 07/2000 Updates
00-08-44-006A JUL 00 Power Antenna - Not Working Properly Or At All
00-06-03-006 JUN 00 Batteries - Settlement of Lawsuit (CA Proposition # 65)
00-08-67-002 JUN 00 Convertable Top - Cleaning and Care of Fabric
00-00-89-012 JUN 00 Labor/Time Guide - 06/2000 Updates
00-06-04-026 JUN 00 PCM - Returned Product Feedback Program
99-01-38-006A MAY 00 A/C - Refrigerant Recovery/Recharge Equipment
00-05-22-004 MAY 00 Brake Fluid - Level & Filling Recommendations
00-06-04-021 MAY 00 EVAP System - Service of Connectors
00-06-01-012 MAY 00 Gasket Surfaces - Use of Surface Conditioning Discs
00-00-89-010 MAY 00 Labor Time Guide - 05/2000 Update
00-07-30-009 MAY 00 Transmission - Identifying Remanufactured Assemblies
00-00-89-004 APR 00 Labor Time Guide - 04/2000 Updates
00-00-89-007 APR 00 Technical Service Bulletin - 03/2000 Summary
99-00-84-021B APR 00 Warranty - GM Dealer Parts Procurement
99-01-39-007A MAR 00 A/C (Automatic) - Operation Explained
00-06-01-008 MAR 00 Accessory Drive Belt - Squeak/Chirp Noise
00-03-10-002 MAR 00 Chrome Wheels - Chemical Staining
00-00-89-002 MAR 00 Labor Time Guide - 03/2000 Update
00-00-89-001 FEB 00 Labor Time Guide - 02/2000 Updates
99-09-41-004 JAN 00 Air Bag (SIR) On-Off Switch Kits, New Parts and Service
00-06-02-001 JAN 00 Engine - Running Hot And/Or Loss of Coolant
00-08-67-001 JAN 00 Folding Top Hydraulic System - Adding Fluid
99-08-66-002A JAN 00 Trap Resistant Trunk Kit - Function/Installation
99-00-89-023 JAN 00 Warranty - Labor Time Guide Updates, 01/00
99-05-23-006 DEC 99 Brakes (Front) - Squeal at Light/Moderate Brake Apply
99-05-23-002A DEC 99 Brakes (Rear) - Groan/Chirp Noise During Apply
99-08-56-002 DEC 99 Theft Alarm - Sounds When Arming
99-00-89-022 DEC 99 Vehicle - The Year 2000 & Electronic Modules
99-00-89-021 DEC 99 Warranty - Labor Time Guide Updates, 12/99
99-08-45-005 NOV 99 Accessory Receptacle/Cigar Lighter - Inoperative
99-08-42-009 NOV 99 IP Dimmer Control - Proper Setting
99-08-46-001 NOV 99 OnStar(R) - Kit Part Numbers and Compatibility
99-03-10-104 NOV 99 PDI - Improper Tire Pressure
99-06-04-053 NOV 99 PROM - Powertrain Control Module Reprogramming
99-00-89-020 NOV 99 Warranty - Labor Time Guide Updates, 11/99
99-08-44-008 OCT 99 Cassette Player - Cleaning and Maintenance
99-06-02-017 OCT 99 Cooling - Radiator Repair/Replacement Guidelines
99-00-89-018 OCT 99 Policy - Changes in Printed Service Information
99-08-52-005 OCT 99 Remote Keyless Entry - Operational Characteristics
99-06-03-008 OCT 99 Starter Motor - Wire Routing Cautions
99-06-03-011 OCT 99 Warranty - Generator Replacement
99-00-89-017 OCT 99 Warranty - Labor Time Guide Updates, 10/99
99-08-48-003 OCT 99 Windshield - Side Moldings Loose
99-00-89-016 SEP 99 Warranty - Labor Time Guide Updates, 09/99
99-08-64-016 SEP 99 Weatherstrips - Use of Silicone Grease for Maintenance
000000A JUL 99 GM Service Bulletin - Disclaimer
99-00-89-010 JUL 99 Warranty - Labor Time Guide Updates, 07/99
99-07-30-011 JUN 99 A/T - Revised Turbine Shaft Seal Installer
99-00-89-008 JUN 99 Warranty - Labor Time Guide Updates, 06/99
99-00-89-006 MAY 99 Warranty - Labor Time Guide - Updated
99-00-89-004 APR 99 Warranty - Labor Time Guide - Update
99-00-89-002 MAR 99 Vehicle - Tips For Using The New Style Service Bulletins
99-00-89-003 MAR 99 Warranty - Labor Time Guide - Updates
68-05-03 JUN 96 Warranty - Goodwrench® Service Lifetime Service Guarantee
http://www.alldata.com/TSB/10/001002IS.html
This is where they all are at.... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
<small>[ February 03, 2003, 11:59 PM: Message edited by: redrumss ]</small>
