Question about ARP bolts on clutch/flywheel
When installing a flywheel and clutch kit do you use ARP lube or lock tight on the ARP bolts?? We have ARP bolts for both and just wanted to make sure b4 we went any farther thanx
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
well i have read in many post saying you must lock tight. I had a friends come apart because he didnt use lock tight, But on the packaging it said use lube but that just doesn't sound right for thise case.
