is my flywheel messed up?
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
ok so on my way home the other day the car started acting weird. it was so hard to shift and the gears seemed like they were engaged all the time . i could put the car in 1st and here something like gears turning . ok so i get home . shut it off and put in in first and start it. kind of jumps in gear with the clutch down or disengaged. so i take it to a shop , they pull the trans and see that i have a broken clutch spring that popped out and i bought a new clutch and had the flywheel turned and put back in . ok good to go until i get out off the garage and at take off with light gas it chatters really bad in 1st and reverse. so my tranny guy DOES NOT like that . so he thinks its the clutch. so he pulls it our and does it all over again . its a little better now but as i drove it and clutched in more and more it seemed to get worse.. now i talked to some guys at motorcity steel and they said sounds like it put hot spots in the flywheel and hardened it in places and so its screwed. anyone else had this happen?![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
