slight grind in 2nd
If your clutch isn't disengaging properly, it can cause the tranny to grind.
If your tranny synchronizers are wearing out, they will start to grind.
Most of the time its the tranny if only one gear is grinding. If the clutch isn't disengaging correctly, each gear would typically grind.
T56 rebuilds cost around $750.
Tony
