Power Braking
Old Jul 10, 2003 | 11:14 PM
JLMoses's Avatar
Default Power Braking
When power brakin in my manual 6 camaro. I cant shift to 2nd gear....would the skip shift cause this? It's got me pissed...
Old Jul 10, 2003 | 11:39 PM
trackbird's Avatar
Default Re: Power Braking
If it is skip shift, the light should be lit on the dash at the time. When it sees you lift, it will likley cause the skip shift to "do it's thing". I'd suggest a line lock, much easier on rear brakes and by not having the rear brakes on, your clutch will thank you....
Old Jul 10, 2003 | 11:41 PM
Sprayin346's Avatar
correct me if i am wrong, but isn't power braking applied to auto's? but as far as skip shift coming into play, it shouldn't be a problem because at like high rpms in a burnout skip shift should be emliminated.
Dane
