T-56 REBUILD INFO
T-56 REBUILD INFO
Where can i get parts to rebuild my tranny. Is their any special tools that i need. I think my imput shaft may be bent. Thanks for any help.
Re: T-56 REBUILD INFO
Your going to need a gear puller thats pretty long. Dunno where you can find it, anyone?
The manual is floating around here somewhere.
Snap On makes a puller that's long enough. It's also ~$250 or so. Serious chunk o change.
My gears slid off using no pullers at all. There's only one gear that gets really tight anyhow. Everything else you can get to with a press & bearing splitter.
-Andrew
-Andrew
