Anyone converted from A4 to M6?
Dope
I spent $1200 on the tranny, X-member, shifter, aluminum DS, used clutch.
I then spent another $300 on new master and new slave to upgrade the hydraulics.
I kept my stock PCM and wiring harness...I plan on flashing my PCM with a M6 program and then going thru LS1 Edit again.
This is a PAIN to do, but worth it!
let me know if u have any specific questions.
Alex
T56's aren't difficult to rebuild. Far easier than A4's. Far cheaper too. I rebuilt one on Sunday using a $300 parts tranny and $80 in new parts. Try that with an A4.
First mod I bought for my car was a Cartek clutch, almost 2 years ago. Car was bone stock at the time. The clutch is still good for 1.4x 60's on the juice (3 weeks ago).
I fragged my T56 a while back (my own stupidity). Rebuilt it myself. Put all new synchros, new 1-2 slider, and new second gear in it. Cost? Under $600 for rebuild. Still going.
I was thinking of putting an auto in my car, but I just enjoy the M6 too much, and it's just too easy to work on.
-Andrew
Nitro Daves-----> in Waco did the swap for $500 a car. Good Luck A4-Bad M6-Good-Travis
Alex
- unbolt driveshaft and unplug all wires and lines
- unbolt A4 (or other automatic trans)
- dump auto in some else's garbage (so you don't have to pay for disposal)
- unbolt flex plate and install flywheel
- install clutch
- install T56 trans.
- install short throw shifter
- go drive and finally have a good car
- install clutch
What's your damage dude. I need a damage report ASAP.
- install clutch
my "instructions" were supposed to be a joke/make a point that its not "that big of a deal".....hence my "dump auto in some else's garbage (so you don't have to pay for disposal)"
After hearing some problems w/mis-shifts, I am sorta glad it's an A4. I do wish I could shift, but must be content
Just an update, I sold my 2000 A4.
Bought a 98 SS M6 (bolt-ons) and a 99 FRC vette M6 (heads/cam).
Sure, I spent a couple more dollars, but I have two sweet cars now
Dope
