Squeaky clutch?
Old Feb 14, 2008 | 11:03 AM
TheSecretFormula's Avatar
Default Squeaky clutch?
My clutch had been having a ton of problems sticking to the floor. So the other day I swapped the master. Everything has been fine since. Until yesterday I noticed a squeak when you push the pedal in and out. I didn't think much of it thinking the rod just needed to be lubricated or something. Well today I realized the sound was louder and coming from the engine bay and possibly the bell housing. Could it be the throwout bearing? Has anyone had this happen? I am going to try to bleed the system again when i get a chance but doubt that it will fix it.
Old Feb 14, 2008 | 11:39 AM
SPEC-01's Avatar
When does the squeak occur?
Old Feb 14, 2008 | 10:21 PM
It was doing it pretty much any time you push the pedal, but it now has seemed to go away completely. Hopefully it was just a fluke.
Old Jul 22, 2008 | 02:35 PM
mycamaroSS's Avatar
happened to me when i release the clutch, really annoying
Old Oct 29, 2008 | 01:13 AM
ls2toy's Avatar
anyone have a solution to this? i'm having the same problem. my project is currently under the knife, but with the t56 and new master cylinder just bled, everytime i push the clutch in and let it out, it squeaks loud, like rubbing wet rubber together. any ideas? since the car build isn't complete, i haven't had a chance to start the car, hopefully it'll just go away
Old Nov 24, 2012 | 09:11 PM
DjinnWS6's Avatar
This just started happening to me today. Every time I press the clutch there is a loud irritating squeek. I'm hoping it just needs some lube somewhere.
