Grinding on fast shifts
Old Feb 13, 2003 | 11:38 PM
Silver Lining's Avatar
Default Grinding on fast shifts
Around town and driving normally the tranny is fine. When I try to shift quickly I end up grinding the gears as its going in gear. I know my clutch is in all the way so thats not the issue. Any help?
Greg
<small>[ February 13, 2003, 11:39 PM: Message edited by: Silver Lining ]</small>
Old Feb 15, 2003 | 03:29 PM
jeff's Avatar
Default Re: Grinding on fast shifts
had the exact same problem. take it to a place that does trannies. and they will tell you u need new syncro's. when i got mine fixed they hooked me up with all new syncros and gears.
1998 Trans Am WS6 M6 Black T-tops
Old Feb 15, 2003 | 07:35 PM
David Plum's Avatar
Could be clutch not fully releasing.
Old Feb 15, 2003 | 11:30 PM
guinness2's Avatar
I had the same problem with mine.Hopefully your car is still under warranty.It sounds like the syncros. Gm replaced my tranny for free!!
Old Feb 16, 2003 | 12:21 AM
99ZEOD's Avatar
It might not be the synchros. Like said before the clutch could be dragging which won't show up during normal driving except maybe some notchy shifting.
Old Feb 16, 2003 | 11:55 AM
silverbullet02's Avatar
T is for Towing not Turbo
jeff, how much did they charge you to do the syncros?
Old Feb 16, 2003 | 01:16 PM
Mean Machine's Avatar
i had this problem on the 1-2 shift. it only happened when i shifted at 4000+ rpms. i think that i had the adjustable stops on my pro 5.0 set wrong, because i have since switched back to the stock hurst shifter and i no longer have this problem.
Old Feb 16, 2003 | 05:33 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99ZEOD:
<strong> It might not be the synchros. Like said before the clutch could be dragging which won't show up during normal driving except maybe some notchy shifting. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I dont think it is my clutch, cuase I have ugraded my clutch and hyrdos not to long ago.
If its my sycros(sp?) i will probably just not worry about it cuase i dont have that much $ to fix it.
Old Feb 17, 2003 | 12:02 AM
jeff's Avatar
it was not cheap at all, it was under warantee. i bought an aftermarket warantee for my car when i first got it. parts + labor i think it was 2,000 bucks man. but i think they might have just did that so they could get more money out of the warantee company, i dunno. alls i know is i didnt pay a dime.
