Clutch Install help needed asap!!
Old Feb 15, 2008 | 06:50 PM
nobreaks254's Avatar
Default Clutch Install help needed asap!!
After I put the flywheel on the crank snout (?) it sticks out too far and wont allow the clutch to sit flat against it. The clutch is hitting the crank end, and yes I have the clutch the right way. Crank is an Eagle 4" and I compaired it to stock and the end is quite abit longer. Clutch is new LS7.
Old Feb 15, 2008 | 07:18 PM
DaddySS's Avatar
So this is an LS2 flywheel?
Old Feb 15, 2008 | 07:56 PM
yes it is
Old Feb 15, 2008 | 08:57 PM
This is where the clutch is hitting the crank.
Here is the gap between the flywheel and clutch when hitting the crank.
