Shim Q w/Spec
Old 02-15-2008, 10:05 PM
2manytoys's Avatar
Default Shim Q w/Spec
So let me see if i understand the info I found during my search. First off I am doing a A4 to T56 swap and the spec3 came with a shim. I did the adj. master mod and from what I have read I don't need to install the shim with an adj. master. Also the shim looks like it is for the flywheel and not the slave. Have not looked to see if one is behind the slave or not. Any help is appreciated.
