Cartek clutch help fast, please
Old Jul 15, 2003 | 11:12 PM
WS6SpdTA's Avatar
Default Cartek clutch help fast, please
Hey guys, I have a question about installing a Cartek clutch. When I put the pressure plate up to the flywheel there are two alignment pins on the flywheel and on my P-Plate there isnt pin holes for it to slip over. So, it makes the P-Plate stick out. My question is, can I remove the alignment pins on the flywheel or drill holes next to the bolt holes on the P-Plate. Will this affect my balance if I do either one?
Thanks for your help.
Pat
Old Jul 16, 2003 | 06:58 AM
nbm00ws6's Avatar
Default Re: Cartek clutch help fast, please
Don't need them, they were alignment holes for the stock set-up but the Cartek set-up doesn't use them. I had them removed when I had my flywheel resurfaced.
Tom
Old Jul 16, 2003 | 11:05 AM
WS6SpdTA's Avatar
Thanks a lot Tom. I thought it would be okay just wanted to ask. I appreciate everything.
Pat
