What fluid should I use in my T-56 as per Tremec techincal support
#42
I see a lot of questions on here asking about what trans fluid should be used in the t-56. I called up Tremec technical support to get the final answer.
-Dexron III is THE most highly recommended all round choice, specifically Texaco/Havoline brand.
-Dexron VI- Still being evaluated and tested, NOT recommended for the T-56 at this time and has caused issues so far in preliminary evaluation.
-Syncromesh- Not really recommended, but can be used in high temp high stress applications(drag racing, very hot climates etc.) since it is thicker than dexron III for some added protection.
-Synthetic- Mobil 1 is the only brand advisable to use and tested by Tremec, can cause shifting issues in colder climates.
So there you go, straight from the manufacturer.
I know, old post.
So I went to try and find Havoline Dexron III here in MI. We don't have it. Word on the street is Havoline is mostly down south now. So I guess after rereading this, I'm going to go with Mobil 1 synthetic ATF fluid. I won't be driving this in the winter anyway. Stinks you can't even find Dexron III in other brands, and when you say something to the people behind the counter, they're like, oh it'll be fine, they supersede eachother. I'm like, nope, see ya later. So anyone find out if Tremec has done any more testing with VI?
Just curious. Mobil 1 here I come. And this is really going to tick me off, because up until now I've refused to buy any Mobil 1 product. Damn.
#43
Probably off-topic, as this has to do with breaking in a freshly rebuilt T-56...
BREAK IN PROCEDURE FOR T56REBUILDS.COM CUSTOM BUILT T56 TRANSMISSIONS
1. 4QTS of Royal Purple Synchromax or mobil 1 ATF will be fine. You can purchase both at your local parts store.
2. Normal driving for 500 miles is required for breakin. Please make this as much stop and go as possible. Dynoing the vehicle is fine during break in.
The instruction sheet was in the crate after I got my tranny back from a T56rebuilds.com (billet keys, carbon fiber synchros, steel 1-2, 3-4, & 5-6 forks, & bronze slipper pads) rebuild; they did an outstanding job on my tranny.
#48
Since this was brought back up thought I'd give another update. I love it still. Only time it was clunky was just like they said it would be in cold weather. Couple times I took the car out in cold weather in winter for a small spin and just had to let trans warm up. Then it's great.
#49
I saw this thread and thought that I would chime in. I ran my stock untouched t-56 for 9 years shifting it over 7,000rpm. When I had it disisembled to have it Pro-shifted, the tranny guy told me it was one of the cleanest tranny he ever saw. He said that you can't shift these tranny's much over 6,500rpm and what was my trick for shifting at 7,000 and having such a clean/min wear tranny.
I told him the trick is GM Syncromesh!
The day I put it in it started shifting smoother and I was able to shift it at higher RPM.
Most all road racing guys are running it also.
GM Syncromesh
Bob
GM Syncromesh
Bob
#50
GM Syncromesh
Bob
GM Syncromesh
Bob
I'VE BEEN WAITING FOR SOMEONE TO SAY THIS!! This is what i've been hearing about the synchromesh and have wanted to try it but it doesn't seem too popular on this website... My friend just put it in his car (honda)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#51
Quote:
Originally Posted by ls1 joe
Yes Mobil 1 is what is preferred by us and most shops we speak with. GM Synchromesh is what is in it from the factory and is a Dextron 3 fluid. Mobil 1 ATF is Dextron 3 compatible.
Amber
They really come from the factory with GM Synchromesh??
Well if this is true, then that is what was in my car when I drained it to put in the Mobil 1 and I'll say it's a lot smother now. So can someone confirm that synchromesh was or was not used from factory fill. I thought it was just a cheap Dexron III
Amber
#55
Amber
Amber
Remember a lot of the road racers that still have the stock synchros are running it.
Bob
