Drag Racing the M6
4k clutch dump + sticky tires + hammering it will usually kill a 10 bolt.
If you are running anything better like a 9inch or 12 bolt, get the stickiest tires you can find, drag radials, slicks etc, bring up the rpm to 4k or higher if you know your drivetrain can handle it and dump away. Requires a damn good clutch, probably a built transmission, good driveshaft, torque arm off the tailshaft of the transmission, and minimum 12 bolt coupled with all the necessary suspension mods.
But 4.10's gear at a minimum.
A set of sticky tires beit bias ply or DOT drag radial
SLP line lock kit
A decent clutch thats had the fluid flushed, the line wrapped
A decent Driveshaft
A Good rears (8.8, 9", 12 bolt....)
Let it fly off the limiter.
Powershift if you dare.
