Ram clutch disc options....
Old Feb 19, 2003 | 09:36 PM
Phil99vette's Avatar
7 Second Club
Default Ram clutch disc options....
Whats the difference between the 300 series, 6130's and 900 series? I have a 346 H & C car that makes >550rwhp on the dyno. Currently using the 6130/402 combo, what would going to either the 300 or 900 do for chatter, holding power, and ease of launching?
Phillip
Old Feb 20, 2003 | 07:14 AM
99MONGOOSE's Avatar
Default Re: Ram clutch disc options....
You must have other mods besides a H/C, because no one has 550RWHP from a H/C package. The 420+ strokers haven't even hit 550RWHP for the most part. If you are using a power adder too then i would go to a 910 disk. Call up mike at Rapid Motorsports, or futral Motorsports.
Old Feb 20, 2003 | 08:09 PM
Stick only's Avatar
300 series is all organic material with steel backings, good with the 402 plate or in the VDS to about 400rwhp. 6000 series is a paddle disc metallic pads, pretty aggressive and really needs a steel flywheel, good to about 500, the 900 series is sintered iron and probably the best material, but also needs a steel flywheel. Wear will be accelerated if you don't use a billet with the last two types.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
