What size are the bolts in the T56 transmisson mount?
I just made my crossmember, and used two M1.50 bolts that partially threaded in to hold it up but i know the are not the right thread. I also tried an M1.25 and various standard sizes. Any idea what size they are? The M1.50 came the closest but it's about as close as an M1.50 comes to threading into the crank (where the flywheel attaches) as i used them to stop the motor from spinning on my engine stand when removing the crank pulley. Could they be the same thread pattern as the flywheel bolts?
M1.5 and 1.25 is the thread pitch. The diameter is probably M15 or so. Don't know if that helps at all.
edit: they are probably smaller like M10 or maybe even M8
