Well I put everything together and went to push on the clutch pedal. It felt fine at first as I checked the fluid level and it was good. I went back in the car to push on the pedal again and it popped, and went to the floor. I looked under the car and it was leaking out of the transmission where the bellhoushing and trans goes together. I took everything apart again and it was the black retainer that holds the throw out bearing. It has about five snaps that hold it together. Underneath that there is a rubber seal that was pooched out.
Do you think I pushed the pedal to hard to the floor and caused it to come appart? I did this with my hand even, not my foot. It really never felt like it had the right pressure like it use to.
Why do you think this keeps coming off? It acts like it's over extending the throw and causing it to pop the tabs.
Any help would be appreciated. Thanks, Pat
