T56 question on fluid
http://cgi.ebay.com/ebaymotors/Honda...em150222539284
still debaiting on which one
, lame I know... The Best V8 Stories One Small Block at Time
They say they use it in manual transmissions that are hard shifting and it fixes them right up. For this reason I would say the honda fluid isn't as good.
Is it ok for '02 T56? Does anyone else use it.
PS it's not Penzoil synchro stuff.
Thanks!!!
The Pennzoil Dex/Merc is fine for any '98-'02 F body T56. I used the Valvoline Dex/Merc for the past couple of years...and am now using GM's current recommended fluid for manual transmissions (their way of saying a repackaged Dex III). Considering you have a later T56 trans w/o paper-lined blockers, you could also use M1 ATF, Red Line D4 ATF, Amsoil ATF, or Pennzoil synchromesh w/o any concern. The Pennzoil synchromesh is a slightly higher viscosity than the ATF's and has a better additive package to reduce gear wear. With that extra viscosity will come some extra notchiness at lower ambient temps. The add packs in M1, RL, Amsoil, and Honda are better than your typical conventional ATF's.
