Rant!
tranny is a rebuilt trem and i just changed the fluid to generic dex III and put some DOT3 clutch fluid in it
just had to rant again on this POS atleast it doesnt ever grind or pop out of gear
its a pattern that is getting old.. then when it doesn't want to behave when im trying to WOT shift
syncros at the least for the popping of gears (once again caused by the hydraulics not disengaging the clutch leading to the syncros doing more of the work to get it in gear)
Hard to get in gear, clutch not disengaging due to hydraulics...
see a pattern here?
Sounds like you are almost beyond saving the thing with a simple bleed. The insistence to do WOT shifting when there are other symptoms already warning against this makes you wonder why the transmission hasn't decided to grenade on you yet.
see a pattern here?
car isn't popping out of gears and doesn't grind at all I dont know if the pumping really works if I kind of try a few times not using to much force it usually does it aswell.. today it was all good went into reverse like nothing about 30 minutes ago after a 30-45 mile drive but this morning no joy... I don't understand if its the transmission fluid in it which is doing that because hydraulic problems should be all the time
How much time and effort are you willing to put into this? If you can do your own work, it might be worth replacing all of the hydraulics, and putting in a bleeder extension to make life easier.
Otherwise, your transmission is gonna need some serious help if you don't get this fixed soon.
I'v already bled the clutch and changed transmission fluid me and my father got a lift so doing the work isn't a issue.. whats this bleeder extension I was going to drill a hole?
If you are clever, you can use a Motive Power bleeder to bleed the system as well
It sounds like you have the equipment...now you need to have the discipline to not try forcing the trans into gear if it doesn't want to go at high RPMs. You may have done some damage already, and getting a quality rebuild is not a cheap proposition.
no funny noises and stuff.. im just debating if I should do a PRO5 at the same time im on stock shifter with short stick and i mean stock stamped
I used to get pissed at mine and just hammer the **** out of it.
If you are doing the hydraulics, the slave bleeder extension is a must in my book. Once you get all of that stuff done, that'll at least eliminate that variable. Hopefully your transmission issues go away along with it...
I've heard pilot bearing horror stories on here as well, and I even rock one of their transmissions, but I can assure you that I'll be running a pilot bearing in my crank for a long, long time.
I wouldn't be at where I am now deciding a LS7 clutch if I wasn't doing my own thing I'd be buying a china made SPEC 3 like everyone
I used to always use the traditional bleeding method with a buddy, and my m6 was notchy, and hard to shift at high rpms. Did a clutch install when none of my friends were around, so i picked up a vacuum bleeder, and bled it from the top. Night and day difference! I've also used it on my buddies cars after they've already been blead traditionally, and have been able to pull out an impressive amount of remaining air from the system. The tool is cheap, the bleed is easy, and it's a good place to start when diagnosing your issues. Last edited by Karpellarpy; Mar 10, 2008 at 07:31 PM. Reason: grammar
$69 for this slave.... with TO whats the little seal for? and the bleeder looks a little diff to
