High RPM Problems...
I have been having trouble with a dead pedal on my 4th gear shift and sometimes even my 3rd. It seems to be strictly a high rpm issue (6,000+). Now that my cam is in, the car will rip all the way to 6,500...so when I am racing, I like to carry it that high.
What happens is I will go to grab 3rd or 4th and it will just be a wall. No grind usually, it just will not let me in. I can also provoke it if the rpms linger before WOT (for instance, a roll type race where rpms may be 4500 for a few seconds before I hit it.)
Does all this sound like pressure plate/clutch related? Seems like the only thing left, considering everything else is new, and we even made the MC adjustable. Above all, my pedal feels great then all of a sudden it will act like this. Whatta ya think?
address those 2 issues first, change fluid, make sure it's bled well then see if you can't shift at high rpm.
with the stock clutch, it won't hold stock power, but it doesn't mean it can't shift at 6000rpm. My car always shifted fine, though the 3-4 was iffy due to the lack of drill mod with my stock hydraulics. Basically I felt there was a difference in the pedal, but not enough to block me out.
the solution is to upgrade to 01-02 hydraulics, do the drill mod, insulate the line, use Dot4 synthetic and finally have a decent clutch. Bare minimum should be the LS7 clutch.
But Im scared I will put in a new clutch and still have trouble. Hope something starts working better, Im starting to feel like I should have kept the A4 in there.
Hydraulics are usually the culprit at high rpm shifting. Still though, if you are running LS6 clutch or lower, then don't expect that clutch to handle 400HP for long.
Your sig indicates headers and headers mean clutch line closer to heat source. Makes sense that you are boiling the fluid on WOT runs. If low rpm, cruising level shifting works like butter, it's heat.
And I don't buy the drill mod thing fixing it. I ran all last season just fine with no issues on stock hydrolics with no drill mod. IMO the clutch just can't handle it after so much heat for so long.
The drill mod DOES help with high rpm shifting. What most don't realize is that at high rpm, the lack of fluid due to the quick shifts puts A LOT of stress on your syncros to make up for the fact the clutch hasn't released completely. This will be apparent when you swap the clutch out. I still have my stocker in the garage, it has blue heat spots all over the flywheel and pressure plate. If your shifts are timed correctly and your technique good along with good syncros, you will not notice the drill mod all that much, but it WILL save your clutch. After about 20 runs at the track with the stock clutch, I started to notice it slipping under WOT load in 1st and 2nd gear. When it finally affect 3rd gear, I went LS7. Season was done, had to wait till 06 before I could test it.
Even with the LS7 and a new hydraulics, it still acted weird at high rpm shifting. Once in awhile I got a grind. It wasn't until I did the drill mod that I finally had enough confidence to hit the track again. I also had the transmission rebuilt and found the syncros were still in good shape indicating I had my shifts done right. Built for 700hp now. 06 has to be a killer year for my car. The drill mod + line insualation + 01-02 hydraulics + LS7 + dot4 has stood up to 100+ passes over the summer and over 20k miles. This was with track days were temps would hit 90's and I'd do hot laps as many as 15 times in a row with drag radials and 315 wide tires. 1.9-2.2 60 fts. Not the best, but protecting the rear is a priority.
My flywheel and pp did have hot spots all over it. I guess I was shifting good then.
You have described what I experience to a T.
This happened with the stock tranny and stock clutch, and also now with my rebuilt T56 with cf blockers, steel shift fork etc and Spec III.
New slave was instaleld a while back - I am hoping then that my system is a good candidate for the "drill mod" and insulating the clutch line.
Any other ideas of addressing this issue?
