automatic guy converting to a t56. Tell me whats good for my application guys!
Old 03-12-2008, 06:31 PM
99DWPTA's Avatar
Default automatic guy converting to a t56. Tell me whats good for my application guys!
well guys
FAWK the 4L60E
Doing the conversion
2001 Trans am LS1 400+rwhp on motor plus 150 shot
Now what clutch is going to handle this?
I'm not looking to replace it every 5000 miles.
I daily drive this car.
I dont want to go cheap.
But i dont want to spend over 1000.00 on a clutch flywheel package.
Is this possiable?
What about shifters. Which shifter shouldi buy?
I understnad maybe some shifters out there hurt trannys?
Am i correct.?
I honselt want the best of the best or close to it.
No sense going cheap the first time as it allways bitesyou in the ***.
Thinking of a six speeds Inc tranny.
Not sure yet.
Could i get away with a stock used T56 for now?
also if anyones got the conversion parts of any sort let me know as i have n othing right now.
Thanks guys!!
Old 03-13-2008, 11:55 AM
jmm98LS1's Avatar
Spec 3+ clutch would be a good match. Shifter is personal preference, I like the factory Hurst w/short stick. Pro 5.0 is a good one too. Don't forget you're going to need a 12 bolt or 9" and at least 4.10 gears.
Old 03-13-2008, 12:01 PM
PewterScreaminMach's Avatar
A Textralia is a little out of your price range ($1,100ish) but would be well worth the money if you're spraying a 150 shot. My brother's 3+ went out in about 4,000 miles, but some people have good luck with them.
I'd say that kind of power on a used stock T56 and you're taking a shot in the dark. It may last you 20,000 miles or more, the synchros may frag on the first first through fourth run. You never know how the person before you drove it. I know someone who's stock tranny went boom with 10,000 miles on it with nothing but bolt-ons.
Six Speeds Inc is highly recommended, especially for your power level.
Old 03-13-2008, 12:02 PM
ndfrsd6's Avatar
six speed inc built mine and no problems A++++ and for sure 4.10's or bigger and dido on the rear end !!
Old 03-13-2008, 12:29 PM
AzzBustin30th's Avatar
just buy all my stuff. :-)
what else will he need for the swap i couldnt think of everthing when we talked on the phone. i told him
bellhousing
flywheel
clutch
slave cylinder
transmission
cross member
shifter
pedal
master cylinder
console
sensors
what wiring would he need and anything i missed?
Old 03-13-2008, 02:34 PM
bellhousing
flywheel
clutch
slave cylinder
transmission
cross member
shifter
pedal
master cylinder
console
sensors
driver mod
Fixed.
Old 03-13-2008, 03:22 PM
DarkJuggalo's Avatar
haha, +1 for driver mod best part of a m6
