T56 Sensors
T56 Sensors
So i got a little Dilema... Everybody Says the T56 Slaps right in place of the NV3500 ( for LS motors) Theres four sensors on the T56, Verse 2 Sensors on the old tranny? How am i suppose to get 4 sensors down there? Run new wires, is there a kit i can buy?
Thats what my T56 Has.... My NV3500 (came out of a 2004 Chevrolet Silverado) Only has 2 Sensors... What am i to do? Thanks
exactly, I swapped one into a S10 years ago. There no need to hook up the skip shift & if you want to use it you can hook up the reverse Lock out to a toggle switch or a switch thats hooked to your brake pedal. Your truck only has the VSS & the back up lights, It will work fine with just those too plugged in.
