Quicktime bellhousing question...
Old Apr 6, 2008 | 08:52 AM
Luna's Avatar
The hole is a pretty decent size. Couldn't some water get in there get on the flywheel/clutch?
Maybe I shouldn't be worried...
Old Apr 6, 2008 | 04:29 PM
n2ojunkie's Avatar
look at the mcleod, it has a starter hole on the driverside that doesnt even get used. Alot of water can get in there also. On the quicktime at least the starter covers up most of the hole, should be fine.
Old Apr 16, 2008 | 07:40 PM
1BADAIR's Avatar
I just bought one today.
it was supposed to be the latest but it came with 7 allen head bolts, aluminum plate and is alot taller than my stocker. What should I do?
Old Apr 16, 2008 | 09:45 PM
John02SS's Avatar
I would contact quicktime, as the one you got is the old design and the master/slave areas are prolly wrong also. They will take care of it.
Old Apr 16, 2008 | 10:05 PM
1BADAIR's Avatar
I sent them an email. Talk about response! They emailed me back at 10:30 PM my time and asked for some pics
Old Apr 17, 2008 | 12:07 PM
stevieturbo's Avatar
I got a fast reply from them.....but a fast reply, is not getting taken care of.
In fact, its pretty worthless when a product is wrong.
Old Apr 17, 2008 | 09:30 PM
1BADAIR's Avatar
they contacted me this morning and gave me the info to return it. Their gonna send me a new one
Old Apr 17, 2008 | 10:23 PM
Luna's Avatar
I need to measure mine, I'm wondering if it is taller than stock because my clutch is disengaging ON the floor
1BADAIR do you have any pics of it ?
Old Apr 18, 2008 | 09:01 AM
My QT was taller than stock. And if you used the motor plate with it too, it would be a LOT taller than stock. Some 1/8" or so.
All I got was a "thanks for telling us it doesnt fit, and the holes are threaded wrong"
Nice to see some others are getting some customer service though, even if I got sweet FA.
Old Apr 18, 2008 | 09:10 AM
Luna's Avatar
Yours had ALOT of other differences from mine too so I'm wondering if the height issue was resolved by the time I got mine.
Old Apr 19, 2008 | 05:55 PM
1BADAIR's Avatar
these are the two pics that quicktime wanted
Old Apr 20, 2008 | 10:29 AM
  #32
Luna's Avatar
That motor plate is alot different than mine. from what I can tell that bellhousing looks the same though.
Old Apr 20, 2008 | 10:47 AM
  #33
never2low's Avatar
Just wondering if you guys had any alignment issues with this or did u just bolt up and go?
Old Apr 20, 2008 | 11:28 AM
  #34
Aside from the problems I already mentioned. Mine did bolt up, and is working.
Due to the height difference, it was not possible to use the aluminium motor plate though.
When bolting the BH to the engine, it would also appear that the flange isnt flat. It does pull flat enough with the bolts though. So not a major issue.
Old Apr 20, 2008 | 11:32 AM
  #35
Luna's Avatar
Any chance you have a measurement of how tall that bellhousing is ?
I need to measure mine against the stock bellhousing. I really hope that motor plate isnt adding extra height over stock otherwise I'm gunna have to pull everything again.
Also, does yours have the same style opening for the slave cyl. hydro lines as stevieturbo? His arent big enough for the quick disconnect. Mine are big enough and are cut all the way back from the top plate back to the part of the bellhousing that starts to curve down.
It seems that 1BADAIR and Stevieturbo may have gotten the same older style bellhousing. Same motor plate anyway.
This really is amazing to me that a company would sell such a poorly designed product. It's pretty clear they've never tried to test fit any of their own products.
Old Apr 20, 2008 | 12:16 PM
  #36
never2low's Avatar
So what you guys are suggesting is maybe look for another product?
Old Apr 20, 2008 | 12:18 PM
  #37
Dont recall of the top of my head. But I have posted it in this forum a couple of times, before and after you asked..
Old Apr 20, 2008 | 12:57 PM
  #38
1BADAIR's Avatar
My bench isn't very flat but the QT was about the same height without the plate.
Old Apr 20, 2008 | 01:19 PM
  #39
Gauge's Avatar
11Second Club
I have one of the newer QT bellhousings where the hydraulic line and bleeder openings are not reversed, and I set it on a flat surface with my stock bellhousing. Using a set of feeler gauges and simply eye-balling and feeling with my fingers, it appeared that the QT bellhousing is approximately .055" taller than the stocker.
I spoke with Ross at QT about some other issues (which you can read about here), and he said that they put in this extra space for aftermarket cranks because they tend to be longer causing the input shaft of the transmission to bottom out in the pilot bearing.
Old Apr 20, 2008 | 11:29 PM
  #40
Luna's Avatar
I was referring to 1BADAIRs unit. It seems there are a few different versions of this thing floating around.
