SPEC 3+ kit... shim???
Thanks guys, I appreciate it.
You said if the shim is not used the clutch will disengage closer to the floor but is that the only issue? Will the clutch slip or wear faster without the shim in there? I only ask because I have a buddy that didn't install the shim on his Camaro.
thanks
Might be better off calling SPEC and getting them to send it.
