Clutch pressed car still moves
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
2001 Camaro SS RAM clutch, OEM slave and master with drill mod. When I start the car I cant get into any gear. I have to have the car off before I grab first or reverse. Once I start the car with the clutch to the floor, the car will move. Once its moving, I can change gears. Sometimes its a little rough but it works.
Clutch? Bad hydro?
Slave was done last year with ample bleeding.
Clutch? Bad hydro?
If the car creeps then the clutch is not fully releasing with the pedal depressed. This is likely related to hydraulics. I would start by checking the fluid. If it is dark or dis-colored then it need to be flushed and refilled. This alone may solve you problem. Try it and let us know what you find. Then we can offer more suggestions as needed. Thanks!
i'm not sure how many miles are on the clutch or the master. the master is NOT adjustable and the fluid is still pretty clean. I put maybe 4k a year on this car, the clutch and master were done maybe a year to a year and a half ago. Last year when i put the slave in, I was having the same issue and installed a spec shim, the problem was 90% gone, than i put the car away for the winter. i took it out and the problem is back.
I could bleed it again and see i guess.
what would you do if the clutch is dragging? hydro's or . . . ?
thanks all, i appreciate it
I had the same problem with my car when I put in a new clutch last fall..
I made my own adjustable Slave..didn't want to spend hundreds of dollars on one, so made my own for less than 10 bux, and after several adjustments got the clutch set right.
**Note, I have an LT1 which is different than the LS1 tranny..but I just wanted to point out the problem is in the hydraulics, and you are most likely going to need an adjstable slave or master. **
What I don't get is why yours is doing it now, and didn't before ??
this has happened before. last year when i isntalled a new slave and shim to help combat this probem, it did a little better. i was able to get reverse and foward from a dead stop. it was still not like butter as it should be but it was better. than the car sat for 8 months i moved to florida from jersey and this is where im at now with the issue. i cant swing a big price tag now after moving 1200 miles and getting into a house down here, so i will try the adjustable master modification this weekend.
![](http://img.photobucket.com/albums/v716/z28toaz34/modifiedslave.jpg)
See the rod on the right..that was the rod in the stock slave...the one on the left was the one I made out of two hardend bolts, two nuts, and a sleeve..and then I ground the ends of the bolts off to be the same as the original one...and presto, I have an adjustable slave!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
