Clutch bleeding
Old Mar 26, 2008 | 06:36 PM
peterock98's Avatar
Default Clutch bleeding
When you bleed clutch do you put the cover back on the reservoir or do leave it off.
Old Mar 26, 2008 | 06:40 PM
mrhzk35404's Avatar
Keep it on. Make sure you have plenty of fluid in there at all times.
Old Mar 26, 2008 | 06:58 PM
ae13291's Avatar
when ever i bleed my clutch i remove the black rubber and just screw on the cap for safety. if you bleed with the black rubber it will try to get sucked into the hole and pulling up the pedel will be a bitch
Old Mar 27, 2008 | 02:44 PM
peterock98's Avatar
The cap has a pin hole on it .
