Loctite
Old Mar 26, 2008 | 01:06 AM
Relapse's Avatar
Default Loctite
Got absolutely everything for this clutch install finally.
EXCEPT the recommended loctite
I've searched around and everyone is suggesting 'Red loctite'.
I visited the main website and there's a lot of specificity involved in choosing a particular loctite.
Also, i have ARP pressure plate bolts and Flywheel bolts. (i've heard that people are concerned that they should use the ARP lube to get an accurate torque reading) What do you guys think?
Oh, and if i use the Red loctite... will i ever be able to uncork those bastards without a heating torch?
If anyone can link me to the **** i need to get, i'd be very appreciative
Old Mar 26, 2008 | 06:30 AM
brad8266's Avatar
I use red on all the clutch component bolts. Ive taken them back off before too without much problem.
Old Mar 26, 2008 | 10:23 AM
Y2K SS's Avatar
Blue Blue Blue.... always use blue. If you want to drop a nut go for the red. I have changed 4 clutches on my car and used blue. Even on the dreaded Textralia Allen pressure plate bolts that are famous for backing out. As long as you torque them to spec they're fine. The blue Loctite is for added insurance.
Old Mar 27, 2008 | 06:26 AM
brad8266's Avatar
And red is even more added insurance.
Old Mar 27, 2008 | 10:10 AM
SladeX's Avatar
I only used red on the ARP flywheel bolts, blue on the pressure plate (and stock bolts no less). It's been 30k+ don't think it's coming off...
Old Mar 27, 2008 | 10:14 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Red red red...always use red. If you can't break a bolt loose that has had red loctite on it, you are a pansy.
Old Mar 27, 2008 | 10:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Ive used blue with great success.
Actually loctite makes a "chap stick" like loctite, its a paste and its for those hard to reach places or if its likely to drip out before setting.
Old Mar 27, 2008 | 02:56 PM
camaroguy26's Avatar
go with the red, those bolts don't get much moisture so they won't rust making it harder, and the bolts are big and strong enough for red. Use blue loctite on smaller bolts that may shear off or round out with too much torque applied.
