Second gear issues Help inside ASAP
Old Jul 26, 2003 | 03:24 AM
twropn's Avatar
Default Second gear issues Help inside ASAP
OK since I bought the car second gear has been a bitch but i learned to get by it. Well now that I am going to sell the beast of course it gets worse.
symptoms:
on the 1-2 shift it feels like every other gear..i.e. slight backpressure right before dropping into gear......then it feels like it goes into gear, then I release the clutch and as soon as there is load on the gear it seems it pops out. Sometimes I can physicaly hold it in, sometimes, but rarely it will not try to jump back out then sometimes I cant even hold it in no matter how much I try.
whats more wierd is after sitting for a while..like a day or so the first couple shifts it shifts into second and hold fine..like nothing at all..soon after that it acts up again.
whats worse is I desperately need to sell the car because basically im broke..therefore I cant even afford to have a shop look at it. I could pull the tranny with one of my friends as I have access to a lift and tranny jack.
As far as I know the tranny hasnt been serviced, should I change to fluid as a first step? if so what weight and what fluid should I use?
I also have the hurst billet plus shifter in it. I idnt install the shifter so I dont know about the stops..or even if it has stops..does this shifter have stops? If so ill check them as soon as I hear back
THANKS!
Old Jul 26, 2003 | 06:59 PM
wrencher's Avatar
wrencher
Default Re: Second gear issues Help inside ASAP
Your problem sound internal trans.
The stops are inside the trans.
It's a syncro/shift fork problem likely.
Old Jul 27, 2003 | 09:42 AM
Camaroholic's Avatar
If you didn't install the shifter or the stops, that's the first thing I'd check. If the stops on the shifter are installed incorrectly, it will cause this problem. I say remove the stops for now, and see if the problem goes away.
If it's not the stops, then I could see internal tranny problems... Possibly broken plastic shift fork pads. But on all gears? That'd be just too weird.
-Andrew
