LT1 M6 clutch bleeding
is it the same as the ls1 clutch bleeding procedure? i dont seem to have a bleeder screw. i lost my clutch friday night. wouldnt go into any gear while running and clutch pressed. while off it goes into any gear just fine. whats happening is the clutch wont release. i replaced the master and the slave and bled many many times. i also backed the transmission off a little so i could see the back of my clutch. looked ok tob still attached. the clutch is also only about 3 weeks old. any tips?
