Just installed spec3+ having hydraulic problem
Old Mar 30, 2008 | 11:55 PM
myws61's Avatar
Exclamation Just installed spec3+ having hydraulic problem
OK so I just got a spec 3+ and installed it saturday, it grabs great!!!!!! But, at the very bottom(floor). I Bled the hell out of it, 3 different times, each time I did it, my buddy and I went through the process more times. we changed all the fluid out and kept doing it until it was clear(thanks ranger for that write up!) but its still doing it. Heres the other thing it did, I was at spring break nationals car show this weekend in daytona, (placed 5 in american) and I was reving the car but I had it in 1st gear and the clutch pedal to the floor, when I reved it low it was fine, when I reved it higher like 5 or 6k the clutch caught and the car jumped a bit. It scared the crap out of me because the pedal was to the floor, I only did it once. Thats my problem.
Im thinking its my slave, but im not sure. If anyone has any suggestions or input feel free to help.
Thanks Jeff, My Ws6
Old Mar 31, 2008 | 08:22 PM
AzzBustin30th's Avatar
clutch is dragging. did you use the shim suplied when installing the kit?
Old Mar 31, 2008 | 11:31 PM
myws61's Avatar
Yes I did.
Old Apr 1, 2008 | 11:38 PM
trey04gto's Avatar
take the shim out and it will work great
Old Apr 1, 2008 | 11:39 PM
trey04gto's Avatar
I have the stg 3+ and billet flywheel and had to do the same thing
Old Apr 2, 2008 | 09:51 AM
myws61's Avatar
you had to take the shim out, but I thought the shim was a must for aftermarket clutchs.....
Old Apr 2, 2008 | 02:03 PM
try making your master cylinder adjustable. and give jeremy at spec a call. and did you replace all the hydrolics with new stuff when you did the swap?
Old Apr 2, 2008 | 02:05 PM
myws61's Avatar
nope none of it, because they are worked fine that morning, It only takes me about an hour to do a clutch, so Its not a big deal to pull it again.
Old Apr 3, 2008 | 05:21 PM
myws61's Avatar
any other ideas guys???
Old Apr 3, 2008 | 07:10 PM
900hpSS's Avatar
I'd say it's air in the lines. sounds like it isn't fully releasing to me.
Old Apr 3, 2008 | 07:52 PM
YellowToy/A's Avatar
Mine releases right at the floor. I was going to pull it and at more shims. I have lived with it far year.
Old Apr 4, 2008 | 11:34 AM
myws61's Avatar
Nope theres no air, Ive bleed it to many times. And how did you drive like that for a year, when I have the pedal to the floor and rev it, it still ingages!!
Old Apr 4, 2008 | 01:45 PM
SPEC-01's Avatar
Guys...pulling the shim will not help this. Here's why, the shim effectively adds height. By removing it you will effectively reduce the throw which will lead to less release. Leave the shim in place...I assume the pedal is releasing about mid-way through its travel...right?
As for hydraulics, just becuase they worked originally doesn't mean that they will continue to work with a new clutch. They may have been weakened over time. How does the car shift? If you pump the pedal do you notice any difference in engagement or release? Let me know and I will be happy to assist with further support. Thanks!
Old Apr 5, 2008 | 07:45 PM
myws61's Avatar
I put a new slave in it today, its still the same, I kept the shim in. The first half the pedal is mushy and does nothing, then it starts to grab, and engages on the floor. Is it time for an ajustable master??? Thanks Spec-01
Old Apr 5, 2008 | 07:55 PM
900hpSS's Avatar
did you set the adjustment on the pressure plate when you installed it?
Old Apr 5, 2008 | 08:19 PM
myws61's Avatar
adjustment on the pressure plate??????????????? on a spec clutch
Old Apr 6, 2008 | 07:43 PM
900hpSS's Avatar
http://paceperformance.com/paceperfo...6ClutchAdj.pdf
this explains how to do it. See if this helps
Old Apr 6, 2008 | 08:31 PM
Y2K SS's Avatar
Dam! what the HELL is that?? Been changing clutches for years on my car and have never seen that. Why doesn't it say to do this anywhere?
Old Apr 7, 2008 | 12:27 PM
900hpSS's Avatar
it should if you look in your service manual.
Old Apr 7, 2008 | 01:47 PM
SSwanner's Avatar
to my knowledge, only the stock PP's are adjustable, (ls1, ls6, ls7's are all SELF adjusting)
