View Poll Results: Which Trans Fluid
Royal Purple Synchromax
13.51%
GM/Pennzoil Synchromesh
40.54%
Regular Coastal brand Dex III from autozone
27.03%
Other
21.62%
Multiple Choice Poll. Voters: 37. You may not vote on this poll
Manual Trans fluid
Old Apr 16, 2008 | 12:01 PM
integraxtc's Avatar
amsoil is synthetic though. I thought I read not to use Royal Purple because it's synthetic.
I'd like to use amsoil as it does wonders on my brother's DSM but if it's synthetic and we're not supposed to then I won't.
I'm just confused.
Also on the Pennzoil Syncromesh are we supposed to add any additive?
Old Apr 22, 2008 | 02:18 PM
TTA1437's Avatar
Im curious about the AMsoil ATF Dextron III as well. My car has 136,000 on it now and im about the change over to the LS7 clutch. I would like to put a good fluid back into the tranny.
Thanks
Old Aug 28, 2008 | 09:32 PM
Crimsonnaire's Avatar
Is it bad if automatic trans fluid is poured into a manual trans?
Old Aug 29, 2008 | 12:08 AM
2002_Z28_Six_Speed's Avatar
Not really. ATF is basically cottonseed oil. It will not dissolve or react with your blocker rings. It is lightweight and cheap. Works great.
Consider other fluids if you have a performance rebuild!
