zo6 clutch
Old Jul 29, 2003 | 06:08 PM
BLULS1Z28's Avatar
Default zo6 clutch
is 450 good for a compleate zo6 clutch kit ready to in stall
Old Jul 29, 2003 | 11:26 PM
2001CamaroGuy's Avatar
Default Re: zo6 clutch
kind of.....they are $500 + shipping from LG so its at least $50-$100 less....
Old Jul 30, 2003 | 03:16 AM
Jabroni's Avatar
Get the part number and check the sponsors sites first. I think I got mine a little less than that last year.
Old Jul 30, 2003 | 12:11 PM
dug's Avatar
dug
THey only have 10% more holding power than the earlier clutches. It might be a waste of money if your engine is making a lot of torque.
Old Jul 30, 2003 | 01:29 PM
SScam68's Avatar
Iam with dug
According to the ls1info site the 00-02 f-bods already had the ZO6 clutch installed.
I would suggest a SPEC Stg II or III if your going to do anything down the road.
Old Jul 30, 2003 | 04:38 PM
BLULS1Z28's Avatar
hear what im getting pilot bearing, z06 clutch kit,and slave cylinder
Old Jul 30, 2003 | 07:02 PM
dug's Avatar
dug
Price sounds about right. Shop around at pace gmpartsdirect and scoggins.
Old Jul 30, 2003 | 08:13 PM
BDD's Avatar
BDD
I paid about that much for my ZO6 clutch setup.
Old Jul 31, 2003 | 01:05 PM
VTtransam's Avatar
I paid $320 for my '02 Zo6 clutch on ebay. It came with clutch disc, pressure plate, and flywheel. This was last summer, I should have just sprung for a spec S3, the Z06 clutch is slipping a bit with the new found H/C power. Didn't know I was going to get heads at the time. I'd recommend just going with an aftermarket kit (spec, ram, etc) getting the McLoed adjuestable master, and a new GM slave. It might run a little more now, but the clutch will last way longer when you keep upping the power. And trust me, the Z06 clutch won't last long once you hit in the upper 300's rwhp range. Save yourself the time and hassle, or you'll be doing the job twice. Of course this is just my personal experience.
Matt
Old Aug 3, 2003 | 09:29 PM
strippedSS's Avatar
00's don't have a z06 clutch. 01's and 02's do
Old Aug 5, 2003 | 12:16 AM
Sleepy383SS's Avatar
Get a Ram, Specs chatter really bad
, and MCLeod are a little sticky for a daily driver in my opnion. The ram is smooth as stock, and will hold way more hp than you have. Like the MCLeod you do need an adjustable master cylinder though.
