need help with drive shaft
Old Apr 21, 2008 | 04:11 PM
thebart455's Avatar
Default need help with drive shaft
im trying to take out my drive shaft to replace u joints. i took off the clips that hold the rear joint but i cant get the shaft to slide
Old Apr 21, 2008 | 04:35 PM
Hilton's Avatar
Tough Mudder
I'm pretty sure I know what you're talking about. Have you heated it up?
Old Apr 21, 2008 | 04:45 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Put a screwdriver between the driveshaft and the pinion on the rear and pry on it.
Old Apr 21, 2008 | 05:01 PM
BarneyMobile's Avatar
^^^ like he said, just pry it off. Might need a big screwdriver or a prybar.
