Losing Clutch Fluid
Losing Clutch Fluid
So I keep on losing hydraulic fluid out of my clutch resevoir. Under the dash on the driver side I have a wet spot on the panel that smells like hydraulic fluid. What is leaking?
Its definetly your master cylinder, and If you replace get an adjustable master cylinder. I got the ram one which is a stock gm master with a rod end welded on the end. You should also do the drill mod or replace the lines with AN lines and fittings that what I did and my **** works ****.
