New Clutch help with high RPM shifting???
Old 05-19-2008, 12:47 PM
dankl's Avatar
Default New Clutch help with high RPM shifting???
Just wondering if replacing my stock clutch would fix the high RPM shifting issues these LS1 seem to have. I have read threads and stickies but haven't come across what I am looking for. Just wondering if it is worth the $$$ to put in a new clutch sytem or not. My clutch is fine besides the high RPM sticking...
Also, if upgrading the clutch will help, what clutch should I go with?
Thanks in advance...
Old 05-19-2008, 12:49 PM
corvet786c's Avatar
I had the same problem and searched as well. My issue was the master cylinder. Get an adjustable one, it fixed my issues.
Old 05-19-2008, 01:12 PM
dankl's Avatar
corvet: So you have the original clutch still, just added an adjustable master cylinder? And this fixed the high RPM shifting issue?
Old 05-20-2008, 03:54 PM
SLP Firehawk's Avatar
i had the same problem and installed a new master with the drill mod no luck
i just replaced my clutch friday so i will let you know how it goes once its broken in
hopfully it fixes the problem or all help is lost
Old 05-20-2008, 05:06 PM
PewterScreaminMach's Avatar
Chances are your clutch is dragging at high RPMs. Do a search in this section on the clutch test and dragging clutch and you'll find a ton of info.
Old 05-20-2008, 07:33 PM
CARTEK Racing
WS6TransAm01's Avatar
What is "high RPM"
I shift at 7000 with my CARTEK clutch and CARTEk adj. master, never had a problem.
Old 05-20-2008, 08:27 PM
dankl's Avatar
high RPM being when I go WOT to probably 6K+ RPM's. Clutch will go almost down to the floor. Gotta pump it in neutral a few time to get it back.
