T56 speed sensor and speedometer
Old 05-20-2008, 04:56 PM
Regency04's Avatar
Default T56 speed sensor and speedometer
I got a T56 out of a 2003 or so dodge viper. It just so happens i got the year viper that they put the speed sensor in the rear diff. So where the speed sensor should go on the transmisson right below the shifter i have a port that has never been drilled out. i could take the tranny back out of my truck and drill the hole for the sensor but then again it doesn't have the reluctor wheel on the output shaft of the tranny so i would have to try and rig something up there as well. So my question for you is does anybody make a aftermarket speed sensor and reulctor wheel that i could mount maybe on the slip yoke or somewhere i haven't thought of? oh and that will work with the factory speedometer.
Old 05-20-2008, 05:19 PM
DanO's Avatar
hope this helps
Old 05-20-2008, 06:12 PM
Regency04's Avatar
Yeah Mine don't have that.
Old 05-21-2008, 07:02 AM
calhoon's Avatar
The trans most likely has no reluctor( tone wheel) Machining the extension to accept the std speed sensor is a little more difficult that what a Black & Decker can do. The Viper uses a hall effect sensor ( produces a positive signal)and is powered. The Fcar is non- powered and produces a sinusoidal signal ( positive and negative pulses) this signal must be conditioned to use for speed( done in the ECM). I suggest you find a Viper sextension already machined an locate a tone wheel & sensor( the same donor part/ trans).
BTW the two tone wheels are also not the same .
Old 05-21-2008, 09:05 AM
thesource's Avatar
I hope you got the Viper trans cheap because you are going to spend a few bucks on this conversion .
Old 05-21-2008, 02:50 PM
Regency04's Avatar
I work in a machine shop so all the maching i get done is free won't cost a thing except for the tone wheel
Old 05-21-2008, 05:40 PM
Regency04's Avatar
Kinda got this figured out. From the info i got off of a viper forum and thanks to six speed inc. I'm getting a machined ls1 t56 reluctor wheel or tone wheel that will fit on the viper output shaft and i'm going to drill the hole for the ls1 t56 speed sensor in the tail housing. total cost will be about 75 dollars for the tone wheel and the speed sensor
Old 05-21-2008, 05:43 PM
Regency04's Avatar
Got another quick question for yall. Can i just take out the reverse soleniod or what can i do to wire it up so i can have it on a switch or some thing
Old 05-22-2008, 06:41 AM
calhoon's Avatar
DON'T take out/ leave out the reverse inhibitor. You can work it through your brake switch or use a momentary type push button.
Old 05-22-2008, 09:25 PM
Regency04's Avatar
lol bad things happen without it i take it. it just take a 12 volt power to run it?
Quick Reply: T56 speed sensor and speedometer
