Reusable Disk?
Reusable Disk?
My Spec 2 crapped out after 3,000 miles. Is it the disk or the pressure plate that wears out?
If it's the pressure plate, would I be able to buy the Autozone Clutch kit and keep my Spec 2 disk?
The "disc" is like brake pads...it is what wears. With that said the PP & flywheel" also wear, like brake rotors, and need to be replaced or resurfaced.
You should replace the disc & PP and get the flywheel resurfaced or replaced.
