Tranny Questions
Old May 28, 2008 | 07:38 PM
WS7_FORMULA's Avatar
Question Tranny Questions
im Not Really Familiar To Transmission Parts....
Whats A Pilot Bearing??
Whats A Throw Out Bearing??
Why The Drill Mod On Flywheel???
Why The Sleeving On The Mc Wire???
Any Help Would Be Nice, Thanks
Old May 28, 2008 | 07:55 PM
Luna's Avatar
Pilot bearing is a bearing that goes inside the crank to kind of hold the input shaft in place and let it turn smoothly.
Throwout bearing goes on top of the slave cylinder to let the pressure plate kind of spin on the head of the slave cylinder.
Drill mod is not on the flywheel its on the hydraulics to make them flow better for smoother high RPM shifts
Sleeve the MC to slave hydraulic hose to prevent the hydraulic fluid from getting too hot and failing.
Old May 28, 2008 | 07:59 PM
Silver98Formula79's Avatar
EDIT just answered
Old May 28, 2008 | 09:10 PM
CW00BlackTA's Avatar
Thowout bearing is pushed by the slave cylinder and forces the pressure plate springs open when you push in the clutch pedal--to release the clutch.
Old May 28, 2008 | 09:31 PM
good info!
so do u really need that drill mod?? and where do u do it??
and the sleeves, how do u do that also? do i have to buy some sort of accessory for that mod???
thanks
