SPEC 3+ durability?
The 3+ is one of the most drivable high capacity clutch kits available...I have driven them in countless vehicles myself and have never thought that they were hard to actuate or use in general. Of course, I am sure that I will be viewed as a biased party, but these are Jeremy opinions/experiences and I reference them as one enthusiast to another!
+1...Very easy to actuate.
Only question I have about this thread is where people comment on "poor installations." What is meant SPECIFICALLY by "poor installation?" The flywheel is either new or cleaned up (machined), the pressure plate/flywheel assembly is balanced, the pressure plate is dowel aligned, a clutch alignment tool is used for the wear disk alignment, the transmission & bell housing are dowel aligned to the rear of the engine. So, what does "poor installation mean?" Does it mean a guy whom didn't clean up the flywheel surface, didn't balance the flywheel/pressure plate assembly,.....what?
Biggest install problem that I can see is that GM should have used an adjustable master cylinder. Further, the use of that damn slave cylinder spacer (on after market set ups) can cause slippage when the clutch pedal isn't even pressed because the spacer has located the slave cylinder too close to the pressure plate fingers. This, of course is not the installer's fault. How is he to know? So, my suggestion for non-stock insalls is to use an adjustable master & can the slave cylinder spacer or @ least find the flywheel to pressure plate finger dimension of a stock assembly & if your after market set up is more (most are), then can the spacer. Anyway, hope this is helpful.
My point in the previous post was that it is unlikely to incorrectly install a clutch because of the self alignment of the assembly. Only incompitence of not balancing, not cleaning up the flywheel,...simple stuff would lead to trouble. It is more likely that guys don't know about the dimensional differences that move the pressure plate fingers closer to the slave cylinder. A guy can spend a lot of time & $ thinking he has is right, installs the spacer, & bam....early wear & a faulty clutch that gets blamed on his installation.
So guys, be aware that there can be dimensional differences as described. You must modify your set up accordingly. Use adjustable masters & can also mean getting rid of the spacer....dimensional checks are critical.
what causes the aluminum flywheel to kill it on the street i am fixin to go with a 3 plus is why im askin to ensure i get the best flywheel plus i plan on doing high rpm launches on it if that makes any difference...
I also had a Alum. FW.... I absolutely hated it on the street. For casual in town shifting the car would drop RPM so fast between gears that it was almost impossible to drive smoothly, or to transition gears smoothly. After the SPEC died I got a TEX OZ700 and went with the billet steel FW... I couldnt be happier.
The actual dimensions aren't as important as noting the difference. To check for dimensional differences, mount both pressure plates to the "new" (to be used on the new set-up) flywheel, one at a time. Measure the dimension from the flywheel to the fingers on each & note any difference. If the new clutch fingers are farther away from the flywheel than on the previous clutch, this means that the fingers are closer to the slave cylinder. So, in order to create the same set-up dimensionally, the difference needs to be eliminated. This can mean removing the slave cylinder spacer &/or an adjustable master cylinder. If the new clutch fingers are closer to the flywheel, this means that the fingers are farther away from the slave cylinder & can mean adding a spacer &/or an adjustable master cylinder.
The only time (shouldn't say only, but, for conversational purposes) that knowing the actual dimension beforehand, is if your current assembly (set-up being removed from the car) didn't last long because of a dimensional problem. This would mean that there is no base dimension for a set-up that has worked properly. However, even in this case, because the set-up didn't last long, it's best to try to move the slave cylinder away from the fingers on the new install. So, just move it out 1/16" or so & give it a try.
The true culprit in dimensional related slip or disengagement problems (if blead properly) is the non-adjustable master used by GM. Having the ability to adjust the volume of oil that passes from the master to the slave cylinder provides adjustability for most dimensional differences.
i have a tex oz700 Zgrip in the vette and im gonna replace it with a spec 3+. I have had to many problems to list with the tex.
