Bad Slave Cylinder???? I'm Feeling Nauseous!!
Thanks for updating your post, I think I may have the same problem. Installed new clutch & slave, bled system, no problems but once I started up car, fluid leaked from bell housing. Now it leaks bad and i can't see that its the connections but I'm going to check them out. The rate at which its leaking out of the bellhousing makes me think that my new slave was bad from the get go. Any thoughts?
By the way, since you got clutch fluid everywhere, did you wind up replacing the new clutch or simply let it be?
Thanks,
Troy
Thanks,
Troy
