HELP Clutch Job Done NO REVERSE!!!
Old 06-08-2008, 02:22 PM
wheeljo2's Avatar
Default HELP Clutch Job Done NO REVERSE!!!
I have a 99 FRC C5 and I just installed a new clutch disc, pressure plate, flywheel, slave & master cylinders and bled the system. Clutch pedal feels great and it engages in 1st gear no problem, will not go into reverse is there a reverse lock-out switch or mechanism that I may have unplugged or something??
Trying to go for a test drive !?!?!?!?!
Old 06-08-2008, 03:01 PM
chuckyt1's Avatar
Sure is. It's on the left side of the trans, by the shifter. Big solenoid.
Old 06-08-2008, 03:09 PM
wheeljo2's Avatar
Ok awesome let me go check. Thanks.
Old 06-08-2008, 03:45 PM
chuckyt1's Avatar
I need to pay attention... I didn't notice it was a C5. I'm not sure where the reverse lockout solenoid is on there.
Old 06-08-2008, 04:40 PM
Viper's Avatar
Also check the ENG SEN fuse; if it's blown so is reverse.
