Mcleod dual disc, weight?
Does anybody know the weight of the flywheel clutch discs, steel plate, and pressure plate for McLeod dual disc?
I'd like to know for both the aluminum and iron flywheel versions, and if you have the stock weights as well that would be great.
Thanks,
Eric
Thanks,
Eric
Re: Mcleod dual disc, weight?
Not sure on the exact weight of the dual-disc setup...but I do know that the steel version is HEAVY.
It probably weighs ~70lbs. for the whole assembly. But double check that with McLeod...my number is just a guess after lifting it.
Scott
Scott
